DonL
I was thinking when it has a design like this.
It could have a resistor or diode built into the coil also. Or the diode and cal resistors will be on the board.
Why not just take the coil apart, and stop farting around ? Don't let a piece of wire scare you. lol
To check the meter you should be able to put low voltage on the terminals to see if it reacts. Even a 1.5 V battery should give you a reading.
Good luck on your project.
