The CI pipe's hub is not a standard size - it can vary foundry to foundry and whether the pipe is 'standard' or heavy duty. They make numerous donuts. The pvc OD is standard, but you need to get the OD of the donut the proper size or it will either be too loose and leak, or be too big and a major pain to be able to insert the pvc, if you can get it in at all once the hub compresses things. As said...to get the right fit, you have to measure the ID of the hub, and get the right one which you might have to special order if you're not lucky. Since CI is heavy, an area may only have stuff from one foundry, and the sizes might be known and the supply house might have the one you need, but it's not guaranteed. It can vary by age, too, so that's not a given, either, which is why they make lots of incremental sizes of the donuts for each size of pipe.
