Two Droplets of drain cleaner
Please, be VERY CAREFUL with drain cleaning chemicals. If your drain is clogged, we recommend that you call a plumber. If you've used chemicals before calling a professional, LET THEM KNOW. These are strong and dangerous solutions and need to be respected if used. Best option is to leave them on the shelf at the home center and call a professional.
Warning, graphic pictures of a burned hand below
https://twodropletsblog.wordpress.com/
JosephJo
Ontario
Thank you for this post. I just moved to my new home and I have some drain and basement problems. Glad that I saw this now. My wife was asking me to get chemical cleaners for the drains.
Sylvan
Still learning
New York
Terry, when Chemicals are used I have a surcharge added a minimum of of $75 for a fixture and $100 for main sewers as these chemicals cannot only cause problems for people working on them it also shortens the life of the cables
Hi Sylvan,
That's good to know. I don't own drain cleaning equipment and I refer that out. I do like to tell people not to use chemicals, and if they do, to let the drain cleaner know before they start. It's not something to be taken lightly.
