David Cowley
- Messages
- 3
- Reaction score
- 0
- Points
- 0
I have a late 60's era 2-inch galvanized pipe well that I have measured to be about 32 feet deep. The pump is Goulds 1/2 hp convertible and was new in 1985. The water level is about 22 feet deep. 30 feet of 1-1/4 PVC runs inside the galvanized pipe down to the packer assembly. There is a small Well-X-Trol tank. The well put out about 3 to 4 GPM at 40 psi from 1987 to 1990 to water the yard, but I lost interest in the lawn and quit using it up until now. Now, after 15 years of being idle, it will only pump a little over 1 GPM at 10 psi. If I just let it run like this for 10 minutes it starts surging and looses suction.
So I pulled and cut all of the PVC pipe up and found that there was no strainer on the bottom of the packer, the check valve was seated by gravity (no spring) and the jet was not clogged. I tried an experiment to see if the well was clogged: I added city water to the well at just the right flow to keep the water level in the well at equilibrium with the top of the well. The flowrate of water that the well consumed was almost 3 GPM.
Does my experiment prove the well is not clogged? Is the packer check valve supposed to be seated by gravity or a spring? Since the PVC couplings are a restriction and the PVC is difficult to remove, can I reassemble this well with flexible PE tube? Dave C.
