Shallow well pump need help ????
Speedbump
Active Member
Riverview, Fl.
Gotcha, so what is this other valve going to do to prevent the heater form seeing the change in pressure?
bob...
djarp
Thanks for all the help , just to let you know you were correct the extra regulator complicated things so I removed it . I also changed my shower head from saver model to a pegasus rain shower and I removed the plastic flow ristrictors in all shower heads. that took care of the problem with the water heater. Also I adjusted the cold water supply valve to the heater allowing enough water to enter and ignite the burners, the presure is excellent all over even when 2 showers are running.
djarp
I made the adjustments to the switch the cycle valve rep walked me thru that but I still had problems with the hot water flashing until I removed those water savers. The heater works great and the water stays at a the temperature you set so you dont need as much hot water. I am running 2 showers at the same time no problem. :D
