The Fluidmaster 7110A SetFast Adjustable Closet Toilet Bolts are designed to be an easy to install bowl-to-floor bolt set that eliminates cutting or breaking off. The innovative design allows for a quick twist adjustment, so the toilet bowl bolts either shorten or lengthen for a perfect fit.
You will still want to use the plastic washer that comes with the caps when installing these. You need those so that the cap has something to snap onto.
