I just realized while attaching the sheetrock in my shower remodel that I screwed directly in to an ABS vent pipe. Was attaching bottom of sheet into the sole plate, so not worried about hitting studs and sure enough I hit the drain pipe straight on. The screw pulled the sheet rock in tight, just like it was standard 2X4. My question is, is this going to cause a problem? It is a standard drywall screw,securely embedded in the pipe about an ch above the concrete. If a problem, what is the best fix? ABS patch or ...?
Thanks for any of your thoughts. Frank
