amilkovits
Hi all -
Installing a new American Standard Americast Cambridge tub into my complete bathroom remodel.
When dryfitting my overflow and drain I found that the screw for the tub shoe is *barely* long enough to catch the drain...and that's dry fitting without any putty under the flange. I'm concerned because I need to install this tub with extremely limited access to the backside/underside of the tub. I have access to see that it is not leaking, but not enough to assemble any plumbing. So, I need to use some of the methods I've learned about here on this site, which essentially call for getting everything in place and glued and then dropping the tub onto it and screwing on the overflow and shoe. I'm worried the short screw on the shoe is going to...well...screw me when it comes time to do this.
I'm using a Kohler Clearflo K-7213 drain, which is a glue up sch 40 pvc cable activated drain. The american standard drains got really bad reviews, and I think (correct me if I am wrong, please) that a glue up PVC drain will be best since I have no access to plumbing and need to set it all up before hand. I've googled a bit and searched this site and haven't seen this problem before. Can I find a longer screw somewhere? Are there drains that you know about that have a longer screw for the shoe? I think the problem is because the Americast tubs have a lot of extra composite material, so it's much thicker than a regular tub at the drain.
What to do?
What to do?
