The new Moen Motionsense faucets use a 1255 Duralast cartridge.
The replace the cartridge, you will need to loosen the faucet and lift it high enough to use the supplied allen wrench that comes with the replacement 1255 cartridge.
The Allen wrench fits in from below.
Or if you have room behind, you can pivot the handle. This faucet was against a wall, so therefore it needed the securing nut under the countertop loosened.
It's the long part of the Allen that is inserted.
The 1255 has three ridges, so you can mess it up when installing. It only goes in one way.
