Bill Alford
WEAJD
We have experienced pin hole leaks in our original hot water copper pipes with a recirculating pump.
This may be from Chloramine in the water supply and thinner walled copper - in conjunction with constantly recirculating the hot water. We had not seen pin hole leaks in the cold water supply.
I have read about PEX lasting substantially longer under the Chloramine conditions. However, I have also read about some chemicals leaching for about six months after PEX install due to how PEX is manufactured. These are chemicals I would rather not drink, such as MTBEs.
To solve both problems, I was wondering about repiping the hot water supply through my home with PEX that is recirculated while repiping with thicker copper pipes the cold water supply that is drank from. The PEX solves the pinhole leaks while the copper avoids chemical leaching into the cold water drinking/cooking supply.
The questions -
1) Is mixing the repiping in this manner advisable? What problems do you see, besides costs and melting PEX when copper is torched.
2) The showers/tubs are using pressure balanced valves that mix cold and hot water together. PEX is typically smaller than copper (equal sizing, eg., 1/2 inch) which may result in different pressures at the valves. Is this a problem or am I over thinking this?
The questions -
