Is my pump going to fall off?
KFULK1
Yakima
Here is a video of my problem. 210ft well 5 horse pump. water hammer after 10 sec of pump coming on. then few sec before pressure starts to raise. then heck of vibration from well head.
thanks for any help.
ThirdGenPump
MA
Are you sure it's a 5hp? At 210ft? Is there a contactor up on the wall somewhere? Nothing in the video lead me to believe the pumps that large.
Edit: wire looks a bit bigger on my computer than on my phone, certainly could be a 5hp.
Do you get air in your water?
My guess is there is multiple check valves in the well. The top ones holding and the drop pipe is leaking into the well.
KFULK1
Yakima
definatlt 210 feet. not 100% posotive its 5 hose but there is the electical control moduel on the wall. It was a used irrigation pump my parents got from our nieghbor 30years ago. he doesnt remember putting more than 1 check valve in when we reinstalled the pump though. the pump its self is probably 35years old. im worried that vibration is going to break the pipe.
I havent notice any air in the lines either. could it be holes in the pipe so the water coming up pushes air out inside the well before it hit the top?
ThirdGenPump
MA
There is probably 2 checks, one integrated into the pump and one right under that well seal. I'd expect you'd see some air but it's hard to say, we don't know the water level, or where the checks might be. it could just leak the pressure and still hold water.
At 35 years old if that is a galvanized drop pipe it's probably in rough shape. It could break with or without vibration. Steel is pretty strong and can sustain a lot of stress but I wouldn't be pushing it at this point, You have a problem in the well, the system has done it's time, time to pull it up.
Unless you are using enormous amounts of water you can probably get the same performance out of a 3HP, which is still an awful lot more than most people need. Go back in with plastic pipe and hope you get another 30 years.
KFULK1
Yakima
I appreciate your feed back. I will get someone out to work on it ASAP.
thanks again!
