Other than the obvious (which is that the previous owner did not winterize several years ago), is there any other reason I might have water in my sprinkler lines?
I'm digging a ditch near the old lines, and I don't plan on using the old lines for irrigation. So I accidentally hit one of the pipes with a digging bar and water started coming out (seeping out, I should say. Not spraying under pressure). Is that to be expected - even after 2 years or so of the sprinklers not getting used?
As far as I can tell the main water supply is turned off in the basement (see picture below - the sprinkler leaves the house supply heading towards the right). Anything I'm missing - and leaking?
Bonus question: anybody know what that thing is in the lower left of the picture? Also, when would I use that drain on the right side of the picture?
Thank you and Happy Friday.
