Dave Armstrong
About a year ago I had two old 50 gallon water heaters with new ones. The installer did two changes to the previous system. 1) He installed an expansion tank, and 2) he put the two water heaters in series (the previous ones were in parallel).
Ever since then we have experienced hot water coming out of our cold taps for the first little bit during usage. This happens for an especially long length of time in the morning.
Trying to troubleshoot this I have installed a check valve on the cold feed line before the expansion tank. I have also adjusted the water pressure in the house down from 75psi to ~50psi (the same pressure I measured on the expansion tank).
I still get hot water coming out of the cold taps.
Any ideas appreciated.
