Down Light's keep going out
JohnfrWhipple
BATHROOM DESIGN & BUILD
North Vancouver, BC
Hey Vegas.
My kitchen has about 12 down lights. All take Par 20 Halogen bulbs. In my daughter's bedroom above the kitchen Island I have four monkey rings. My girls and their friends no matter how hard I try continue to stop it land flips and such hard. The impact and vibration is unscrewing the lights. I swear on day they are coming through the ceiling...
Sometimes blowing the bulbs.
I'm getting sick of the lights going out - taking the monkey rings down is not an option.
Any tricks or specific brands of light bulb I should try. Are any Par20 bulbs designed for vibration?
Vegas_sparky
Digital Billy
LV,NV/ Nowhere,UT
I agree with Don. LEDs are the only way to go. I can't think of a circumstance where they aren't the superior alternative, except for an easy bake oven.
Here's a very good LED lamp, and 5000k will be very white light, suitable for working on plans and homework at the island. Good LEDs aren't cheap, but have a very good ROI in areas of high usage. I've gone all LED at the UT house, and that saves a minimum of $30/month on the power bill for a 4K sq/ft home. Changing out all your general task lighting lamps(kitch/baths/closets/ family rms)will give you the greatest returns.
Feit PAR20/5K/LEDG5 LED Dimmable PAR20 5K Reflector GEN5
IF the bulbs were "burning out" because of the vibration then a "vibration proof" bulb would help, but your bulbs are "unscrewing" meaning you may need a lighter bulb to reduce the momentum when it shakes.
JohnfrWhipple
North Vancouver, BC
They're unscrewing because John's installing them like a girl. Use your man hands man. LOL
Your such a Douche Bag.... LOL
They are tight.
Today at soccer one of the dad's asked my what the trick was for dropping the tent. You have to push in this little button to let the tent top slide down the leg. He tried on his leg while I did two (my side and another dad's). He still did not get his side done.
I told him the trick was to take off his panties first! LOL
JohnfrWhipple
North Vancouver, BC
LED bulbs.
OK.
Then I need to buy 16 $&&ing LED bulbs. That is going to cost me a fortune.
I better do a test. Try one and see how it holds up.
Thanks Vegas.
Vegas_sparky
Digital Billy
LV,NV/ Nowhere,UT
There's definitely an upfront cost, but they do pay for themselves. You can calculate a rough estimate for ROI knowing total number of lamps to be changed, new lamp wattage(7-12w depending on lamp), old lamp wattage, average on time per day, and kW/h rate. I bet those kitchen and island lights are left on more than you'd expect. 16 incandescents are burning a lot of power.
I'd test one if I were you, just to make sure you like the color of the particular light you choose. 5000k will be on the whiter(cool) side, while most are used to a warm white color(3000k-4000k). You can also go with a dimmer on the 5000ks which will pull down the total light output to soften them up.
DonL
Houston, TX
Money should not be a problem for John.
Do I sense a Tight Ass here ? Glad he has me blocked, but feel free to tell what I said.
The LED will maybe never need to be replaced again if you buy good ones.
Cree gets my Vote. Made in USA, so Far.
Vegas_sparky
Digital Billy
LV,NV/ Nowhere,UT
I'm a CREE fan also, when they're available. I am expecting a 126w LED light bar in the mail today. Its going to go on the front of my wife's car for backwoods night driving. These things are starting to come in at realistic price points.
JohnfrWhipple
North Vancouver, BC
Vegas.
This one?
My Lights now are Par 20's. They look more like this LED build.
http://www.myledlight.com/par20_led_light_bulb_36_leds.aspx
These are whats i there now.
Vegas_sparky
Digital Billy
LV,NV/ Nowhere,UT
That first one you show is some kind of type A looking lamp, John. I threw in a link to a good quality lamp in my first reply.
Here's something else that'll help with your shower LED installs. My LED light bar showed up, and I always add a little extra protection on the surfaces that get pounded with water the hardest. Flowable silicone is great for sealing tight joints, where its difficult to use the typical type. I'll seal a downward edge, let gravity do its thing for an hour, rotate 90°, and repeat until its bulletproof around the face. Tonight I'll test the output of this bar against the existing lighting on my truck(180W HID + 265W dedicated halogen long range driving lights).
JohnfrWhipple
North Vancouver, BC
Vegas my Shower lighting systems don't get wet. They are outside the water and vapour proofing measures.
My last client is a auto mechanic and works here for Ford. He also travels with his boss as part of a pit crew for NASCAR. He was telling me about waterproof heat shrink. Still have not got any samples of this and keep trig to find it.
Have you use any waterproof heat shrink before?
Vegas_sparky
Digital Billy
LV,NV/ Nowhere,UT
I have. Heat shrink and various sealents are my approach to prepping strip LEDs. No heat shrink alone will fill the void between loose conductors.
JWelectric
Electrical Contractor/Instructor
North Carolina
Hey Vegas.
If taking down the rings is not an option then maybe getting rid of the kids would work. I think I would consider one or the other before I found one of the kids in the kitchen after the floor gave away
JohnfrWhipple
North Vancouver, BC
LOL - I'll talk to my wife. The little one is quite annoying at times! lol
Koa
Honolulu, Hawaii
Those Cree bulbs are designed to light more sideways as opposed to up or down depending how you mount them. There's a dark spot on top the bulb. You would need LED floods. If you replace your halogens with an LED with built in trim rings you would only be screwing in the connector to the bulb not the bulb. You could pinch the socket a little (which might also work for your halogens) and pre twist the wires so there's tension on the connector after you screw it in. You tend to lose some of the dimming range with LEDs and some bulbs are not instant on which I find annoying. Also there is more glare with LED floods bare bulbs.
Maybe some mats or futons on the floor of your girl's room might help.
