dschag
Hello. I live in the Los Angeles area, in the mountains with a lot of thick, dry chaparral. I've put in a watering system on top of the ground until I can decide if it is the best I can do. It doesn't throw as much water as I had hoped, where I would like it, and would like to identify the elements and see anyone can suggest improvements. Here's what I have:
The reason different lengths and number of heads is due to trying to maximize desired water effect and just adjusted lengths and heads based on performance. For some reason the 150' section performs better, thus has more heads. I'm just wondering if my design is pretty solid and whether I could pick up some through flow performance (more volume, more distance, etc.) through a different configuration. Are the valves restricting the flow? Should I be taping into the 2 1/2" main directly? Are the rainbird impact sprinklers the best for throwing a distance, moving back and forth, and scattering water high and low?
Or, maybe I don't even know the question I really should be asking? Thanks for any comments or ideas.
- Roughly 300' perimeter
- 10,000 gallon water tank running off a well
- The water pump is a vertical type that was designed to accommodate remote fire hydrants (as I understand it, the pumps ramps up speed as water is demanded)
- I have a 2 1/2" water line out of pump that goes to the house (where, of course, the pressure is regulated to about 65 lbs)
- Before split to house, I have a 2" line (then stepping down to 1 1/2" then to 1") going into two in ground water cabinets that use 3/4" rainbird electric valves
- OK, so off of 3 separate valves, I have run 3 lines of 3/4" pvc:
- 75' with 4 rainbird impact sprinklers mounted on 1/2" risers that are 3' tall and aimed at my roofs
- 150' with 7 sprinklers (as above)
- 125' with 5 sprinklers (as above)
