Clients "friend" did work- Need Tile advise Kitchen
Discussion in 'Remodel Forum & Blog' started by skydec, Jul 31, 2014.
  1. skydec
    skydec New Member
    Jul 31, 2014
    Okay A Clients "friend" told her he could do work cheaper than contractors I had quotes from. Apparently does this as side job. NOT his day job. So no licence, no insurance.... I supplied tile and Hardie board, Her walls have lots of movement _ leaky Condo originally. So he removed tile and has been replacing with her old Drywall in patches. Hardie board unused. Bent piece was I assume for return to window since there is matching piece (with huge gap @ top) other side. He was also to do tile, I have done tile before for her, but usually hire as I am shopping , refinishing some of her furniture and other things on this job. Ames , tile contractors suggested Hardie for 2 reasons - movement in walls and and fact that I have been wiping counter of water every day, I assume is from sprayer less than 1" from backsplash.
    So after talking to him I have concerns: Return to window on opposite wall that was not square, I asked to fix he removed completely, will not put back.
    Where do I end Tile, so design issue?
    #1 I asked if he needed new blade for the glass I had one- Has no Idea he said what size blade his saw uses. #2 Had no Idea what rondec profile was #3 wanted to use thinset over Mud he has everywhere to cover patches. Will Priming these walls be enough???
    He has also built her a new mantle n(before I got there for makeover) for replacement for a heavy new tv. Ledgestone was put up to old from above down to top from above. He removed NO rows of the China Multi ledgestone (still avalible @ Ames )- NOW ledgestone below on 1 side is A) no longer flush to walls. B) I have found bits of mortar on floor. People that have looked @ it, said looks like Lag bolts, is what was installed with.
    I would have had it installed TV above mantle or steel rods for mantle.
    He has told her he did reno for Architect in area so she assumes he is great, She of course wants done ASAP. which if he had not said anything all work would have been done. Of course I can not get tile guys -they are on new job. I did tell her my concerns.
  2. hj
    Tell her your concerns and walk away. This may be a situation that you cannot win.
  4. johnfrwhipple
    johnfrwhipple BATHROOM DESIGN & BUILD for both Canada & the US
    Jul 20, 2009
    Design Work World Wide: Bathrooms Vancouver Area
    North Vancouver, BC
    Is that a bucket of mastic in the photo! Yuck.
    Hardi Board will not help with movement.
    Using scrap drywall is a green building in my book - I do it all the time.
    I would have first prepped the area for tile. Used proper edging pieces. Coated the job tile area out with Ardex 8+9 or mapei's prim grip.
    Then tile and grout.
    You need better pictures or more of them.
  5. skydec
    skydec New Member
    Jul 31, 2014
    I keep getting asked by her ,when I am finishing my part, Cant Paint till I clean, cant clean until he is finished with drywall we are now on day 6- still not done. No clue why, my regular drywaller is horrified he used her 26 year old drywall - has no idea why he is taking so long either. Told him, Charges by the hour does not give estimates. Can't bring in her new art or furniture in either Art Canvas just got cleaned, he has drywall throughout entire condo. I have worked with this client several times, Love her. This would have been all done if she had just gone with one my regular contractors. Oh and they clean up and put barrier up for dust.
  6. skydec
    skydec New Member
    Jul 31, 2014
    This was my first look @ quality of his work He took off old mantle to make a larger one for her larger TV. Problem is ledgestone went right up to bottom and down to top of old. He did not remove any to get it in. TV is heavy mantel installed with lag bolts, I am told and was also told "he a a lot of trouble getting it shoved in" I am nervous with that TV there.
    Jim Whipple wrote "Using scrap drywall is a green building in my book - I do it all the time."
    Really you use 26 year old, drywall. 3 different paints on and primer that I know of ( yes I told him) I painted it over the years. Hardie was Also to be used
    where needed because her faucet is less than 1" from backsplash and counter often has water sitting on it. There were areas of black on grout.
    Would it also take you 6 days for 40 sq. ft of drywall.????? Rooms of drywall have not taken this long. Hardie is firmer than that drywall.
  7. skydec
    skydec New Member
    Jul 31, 2014
    I added more info see new pics
  8. johnfrwhipple
    Jul 20, 2009
    North Vancouver, BC
    Of course there are exceptions. Often I remove large sheets of drywall that are in perfect condition. These I use for new drywall work sometimes. Temporary floor protection. Templates. Lots of things.
    Nasty old drywall of that age may contain asbestos so that would be taken out to Langley for disposal.
  9. skydec
    skydec New Member
    Jul 31, 2014
    Also he was going to dump illegally - I said No way - Arranged for disposal. Also we are now on 7 days of sanding. for small galley kitchen. He was to do tile , install window ledge, Has made window 76" - larger for me, he said- I had told him I needed it to be 75 for new blind. He wanted to put tile on and ledge over tile, When I pointed out design of tile & if client wanted to change it? his answer was "why would you change tile?" uses phrase "it is good enough" all the time. Client has now had enough, realizes her mistake having me cancel people I had, who now I can not get, there is dust and drywall mud EVERYWHERE. So I have to have this project at her house done by August 8.
    Ever tried to find someone on a long weekend and for next week???
  10. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    You've got a handyman not a pro and he's giving you handyman work. You get what you pay for...if you're luck. In this case, you may not get what you pay for.
  11. skydec
    skydec New Member
    Jul 31, 2014
    I told my client just that, Also told her it was time to get a real trade. He charges by the hour , No clue how much will not tell me- her friend she is paying him. 7 days and this is his finished work Can still see metal , which I said was not acceptable
    See Photo
  12. Gary Swart
    Sep 1, 2004
    Yakima WA
    Your first mistake was getting involved with this. Your second mistake is staying with it. Butt out and have a beer.
  13. johnfrwhipple
    Jul 20, 2009
    North Vancouver, BC
    Drywall picture looks like the corner is loaded up and just needs a sand and prime.
    I don't think that's finished product yet.
  14. skydec
    skydec New Member
    Jul 31, 2014
    Update- Finally Client " let her friend go" After I said, as politely as possible, that had I (inside voice-lost my mind &) hired him, he would have been let go. Could not get who had originally wanted - busy, go figure. Hired someone else to fix and finish his "finished drywall" who was fantastic. I tiled over . Client ended up with delays and paying more $$ and then if she just went with people I wanted in first place. Old drywall her friend put up actually came away around outlets, plaster fell on counter overnight - So had to fix. While loading drywall pieces her friend did throw away , for disposal we noticed mold on some of it as well.
  15. 8claw
    8claw Guest
    That sounds much better now. I guess that you have already fixed all your problems and can't wait to see a picture of the finished product.
