Gpace1
Retired
Sooo, what is the correct, step-by-step procedure to fill and/or adjust air pressure in a bladder pressure tank.
I have a challenger 85 gal. I would like to set my switch at 40/70. Assuming the pump is still powered off, do I then drain the water from the tank and adjust the air pressure?
I know how to adjust the switch. It's the filling of the tank where I am having difficulty.
What should the status of the pump be at while filling tank? Powered off?
Should tank be filled with water? If I were to create a step by step:
1. Check switch settings:
a. open faucet
b. watch gauge drop til motor kicks on (40psi)
c. close faucet
d. watch gauge rise til motor quits (70psi)
2. Adjust air in tank:
a. Just adjust air at this point ?????? OR
b. drain water in tank, then adjust air ?????? OR.....
Any help will be apppreciated
THX
Gene
a. open faucet
c. close faucet
THX
Gene
