Bathtub shoe drain too short
repair
Honolulu, HI
I live in a high rise and have an above floor rough bathtub. The problem is the drain is too short to the tub, about 5/8". That's the p trap at the corner. Anyone have any suggestions?
FullySprinklered
Georgia
The drain is too short to the tub by 5/8 in. In other words, you need to raise the drain up closer to the bottom of the tub, I assume.
Fitting-wise, there's nothing that will give you 5/8 " within the area under the tub. Maybe somewhere in all that brown fluff in the wall you could rotate up a 22.5 street el and a regular 22.5 el to get the rise that you need, the bring it back square with other fittings. This is a tough one and will take a lot of trial and error . Might have to get radical with the p-trap. Get a basket full of fittings and go to work on it.
repair
Honolulu, HI
I got some 22.5 elbows and it looks like it should work when dry fitting. There's not much room to adjust so the angles have to be perfect. Are there any tips when gluing the pvc fittings since they move around when I take it out to glue.
Erico
Chicago, IL
Once you get everything lined up, mark the position of all the fittings with a sharpie. Draw a hash mark across each fitting. Make sure the marks are long enough on the street fitting so the primer/glue doesn't erase your reference lines. Don't over do the glue on the street fittings.
When gluing, start out of position by a 1/4 to 1/2 turn then spin the fittings to line up hash marks.
