I use a cistern for drinking water and all household use other than irrigation. 30 years ago when I built the house I took bad advice and put a jet pump and pressure tank in the crawl space (right under the TV). The first pump lasted 15 years, and burned out due to running it dry, house guest wondered whats that noise? The second one is going just fine but I am getting sick of the noise. Talked to a couple of local plumbers about puting a submersable in the tank, but none wanted to mess with it.
The question I have is are there any jet pumps that are appreciably quieter than others? Is putting a submersable just too big a job to bother with? My tank is a concrete vault and is still water tight after 30 years. Any suggestions?
