Tim Fastle
After an addition I have to move my pressure tanks from the garage to the newly added shop (approx 50', all indoors). I am adding a filter and softener and if I leave the pressure tank it is the filter and softener I am adding will be "behind" the pressure tank and have reverse flow to my outside water supplies (tees off before house water). My plan is to move the tank so it will be before the filter, softener and inlets to the guest and main house but after the lines to the yards. The problem I have is, the pressure switch and wiring is located at the old tank location. Originally I thought I was fine with that but I now realize that if I leave the pressure switch there, if for some reason I shut the water off (close a valve) before the pressure switch, say at the new tank location, then there is no pressure switch in line to turn the pump off. Ideally I would like to move the pressure switch to be before the filter and softener but have no wiring in place (3 strands from controller to new pressure switch location) for that and would rather not have to run through fully finished, bedroom, guest house and shop.
Does anyone know of a remote or relay operated (low voltage, small wires) "remote" pressure switch option or have any ideas on a good way to do this. Another option, but not ideal, is to leave the pressure switch where it is and make sure that any time any valve before it is closed that power to the well is off and then, put a pressure relief valve at the new tank location just in case a valve is closed and the well pump power is not cut.
Any thoughts, input, ideas would be greatly appreciated. I've attached a quick, not to scale drawing of what I have and am doing.
