Amopower
Hi all,
I recently replaced my well pump (used for irrigation only), with an exact replacement. (Flint & Walling 3/4hp, jet pump). I just bought this house and apparently the previous owner had not run the irrigation for at least ten years. Since the pump looked like it was at the end of its life, and because i wasn't getting enough water, I replaced it.
I also replaced the two lines coming in and out of the pump with clear PVC so i could see what is going on. Glad I did, because what I see is air coming in the line entering the pump, which in turn is affecting its ability to keep up with the demand. (pump basically drops immediately from 55 psi to 35 psi when i turn on an irrigation zone, and the pump runs continuously until the zone is turned off. The sprinkler heads pop up strongly at first but then slowly die down to a low level)
My thoughts are that there is either a crack in the piping somewhere along the line, or that it's sucking in some air at the foot valve because the water table is dropped low enough to be around the foot valve. Is there anything i can do to prove either of these? I wasn't sure how to locate the well head. I see where the pipes come out under the house and then under the sidewalk, but that's about it.
I would say the system is about 25 years old.
thanks
Scott
thanks
Scott
