Texas Wellman
Excellent news. It's always exciting to be able to save a well like that. When you go back you should consider a 3" pump (Google Grundfos SQ) or a slim-line 4". The slim line 4" is slightly smaller than the normal diameter but the motor is the same size. I would jet the well with an air compresor if available to clear any debris and run the camera down afterwards to inspect. Be sure to put it back on steel pipe unless the pipe in the well is completely ate up. Steel pipe is so much stronger it allows you to pull much more than any other material.
