All Blog Entries
  1. Bur Cam Pump 503321
    This past weekend installed- Subject- Pump in my cottage to replace old pump shallow well configuration.
    Primed pump and got water to taps. I also got a spray of water from the rubber gasket between Ejector and Pump housing. Also tried another type gasket material with same results.
    Amy Ideas? Could matting surfaces not be flat?
    Dirt Water Fox
    Categories
    Uncategorized
  2. Simple Facts About Registry Cleaner That You Should Be Aware Of
    The dreaded blue screen error affects everyone at some point or another. Why these things happen is generally a mystery. Frequently when the http://registrycleaners10.com/speedypc-pro-review/ occur, a job is being executed and the suddenly the system crashes. A lot of figures and words flash across the screen and then your system reboots. Thus there's no concept of what caused the mistake.
    To fix this problem go into the startup menu when windows is booting, and then find the option ...
    Categories
    Uncategorized
  3. Solar and wind installations
    Hello, i currently have solar and wind at my home among other solar products to combat the recent increases in utility rates. i also install these systems for a living. i was wondering fif anone else has any of thee se system in place at their home and would like to discuss.
  4. Adding a bath
    I HAVE A ONE STORY RANCH HOUSE ON A SLAB. I WANT TO ADD A SECOND BATH. THERE IS A 4" VENT STACK BETWEEN THE TOILET AND THE SEPTIC SYSTEM 8' FROM THE EXISTING TOILET. THERE IS A 2" VENT AT THE BATH ROOM NEAR THE TOILET AND THE SINK IN THE BATHROOM. I WANT TO ADD A BACKFLOW TOILET TO THE EXISTING 4" STACK. I DON"T HAVE MUCH ROOM TO CUT THE PIPE. I WANT TO ADD A 4X3 SADDLE REDUCER TO THE STEEL VENT PIPE. WHEN I WAS WORKING AS A FITTER I WOULD USE A 4X3 BOLT ON SADDLE WITH SOME SORT ...
    Categories
    Uncategorized
  5. fuel combustion
    Dear All,
    Can anybody tell me, why only air is used for achieving proper combustion. Why not we use only oxygen, which plays a vital role in combustion process, even we know that air contains nitrogen (79%) which is inert and contribute to NOx formation and heat loss.
    Regards
    Categories
    Uncategorized
