View Full Version : Special Fitting?
Joe J
01-23-2005, 03:19 PM
Hello all,
I am in the process of a complete remodel of my 3/4 bath. I have encountered an unusual PVC Y fitting. It is a 7 1/2 long, 3x4x2 y. The 4" section connects to the old 4" cast iron but it is labeled Permafit and has the # 45174 on it. Is this a special sleeve or a special Y fitting? I googled Permafit and Colonial Engineering and could not find anything. Extra space is nonexistant so I must find a replacement. Please advise.
Respectfully,
Joe
macleod
02-13-2005, 11:31 PM
Joe,
I also encountered an unusual fitting in my bathroom remodel. You can try looking up the fitting on a manufacturer website like Nibco - www.nibco.com (http://www.nibco.com), they make plastic fittings.
I found that to actually buy the fitting, I could not go to HD or Lowes, I had to go to a couple of pipe supply stores until I found one that did enough volume to stock the part I needed, a 4" elbow with low heel vent inlet.
In my area, Ferguson was that store - I think they are a nationwide chain of plumbing supply houses. If you take the fitting into the store, they may be able to help you. This is definitely one area where the service at a plumbing supply house is worth it. Plus, they may have doughnuts if you go early enough. ;)
good luck,
Jason MacLeod
http://www.terrylove.com/forums/attachment.php?attachmentid=6020&stc=1&d=1230323207
RioHyde
02-14-2005, 10:27 PM
Could you post a picture of the fitting?
