sanderst24541
12-06-2006, 09:28 AM
Hi,
My submersible pump didn't shut off yesterday for app. 1hr.
I finally realized it was on and before I could pull the disconnect the pressure guage was pegged ove 100psi. Turns out the contacts had fused shut allowing the pump to run nonstop. My question is: How much damage may have occured with such high pressure and does a submersible pump have a relief valve for all the water to go by.(ie- where did all the water pumping for an hour go to?)
Other than a few drip leaks I can't find any damage or areas of water leakage.
This definately is one of those things where one problem leads to alot of others.
