corner shelf in shower
Wallace 49
I'm using 6 inch white tile on my shower walls over my new tub. Does anyone have an opinion about using ceramic corner shelves? Do they become elbow or head bangers? Which end of the shower stall should it be placed? Thanks
shelf
If you are going to use it for shower related items, it would go at the shower head end so you do not have to turn around or reach behind you. It would not normally be large enough to create a hazard.
Depends on the size of your shower. if it's less than 40ish" deep, then it might be an issue.
The 'in' thing to do is to make build a recessed niche into the wall. They have preformed recesses (search noble niche) that get cemented into a stud cavity. No hazard. Looks beautiful. They even have double level and arched ones that give a ledge for shampoos and a separate one for soap. Try not to place niche in direct line of spray.
Corner shelves can be placed on either inside corner.
IMHO the shelves should go in the end of the tub opposite the water controls. Avoids the bar of soap getting unnecessarily dissolved by water spray.
corain corners
in my own tub I have a corian shelf ....
they are basically triangles that simnply go into the corner and
you tile around them.... I have a fairley large one...it holds lots
of shampoos ect...
you can get them at any decent tile outlet....
.much more durable than a china shelf.
If I had to do it again I would probably have put one
on both ends of the tub...
