psaw
11-28-2006, 11:13 AM
I have a house built in the 60s that has a copper 3 inch main vent. The pipe is corroded most of the way up and is leaking small amounts of sewer gas. I want to replace the pipe, but want to use ABS or PVC. The problem is that the wall is 3 1/2" thick (2x4 studs) and the OD on plastic is bigger than copper. On top of this, the tub and sink vents connect in the wall. A typical hub on a plastic connector is 4" which does not fit in the existing wall space. Any thoughts on solutions so I don't have to rebuild the wall? Thanks
