chadzeilenga
11-27-2006, 11:03 PM
Hello,
I recently purchased an old (100yr) 2-flat apartment building that I am having some minor plumbing problems with. I recently had to have a plumber come and rod out the sewer line to the city sewer system because the building was vacant and tree roots had clogged the system up for the new tenants soon after they moved in.
We got all of the roots out and the water flows great now, but when we removed the PVC cap from the clean-out on the cast-iron main stack I noticed that it wasn't threaded on very well, just sealed up with putty. After we were done I tried to thread the plug back on it would not thread. I looked closer and saw that much of the threads on the cast-iron female section were worn away probably from previous sewer rodding and the previous owner just used sealant to hold the cap in place.
Is there a way to repair this without cutting apart the main stack and breaking up the concrete floor to replace the section of pipe with the clean-out on it? I am thinking that there might be a plug similar to that on a row boat which you turn a center screw and it expands the rubber outer part to seal the hole? I don't think that the threads are dirty, they are just worn away.
Any suggestions?
Thanks,
Chad
Any suggestions?
Thanks,
Chad
