View Full Version : tub wont drain
meridian
11-20-2006, 10:51 PM
I have a full tub that wont drain at all. I took out the link mechanism - which seems to have stopped working a while ago but it did always drain slowly - that has a coil spring on the end and also took out the pop up stopper at the drain bottom. It wont drain with the pop up stopper out. Is there a lift bucket in this tub drain??..I thought the spring on the end of the link pushed against the pop up link to open/close the drain??
Now I've got a full tub and don't know what to do. I tried putting the link and spring back in and moving it a million ways but it is all buggered up! I can tell just by the way the lever turns that it isn't doing what it is supposed to do.
any ideas??
The tub needs to be snaked.
I would call a plumber at this point so you can get a shower soon.
After watching him do it you can then decide weather to do it your self next time or that You will just call him back.
plumber1
11-21-2006, 05:33 AM
Sounds like an American Standard tub waste and overflow and you have all of the internal parts out.
And the drain needs to be cleaned with a snake. Be sure you don't pour drain chemicals down there.......
meridian
11-21-2006, 06:39 PM
Thanks for your replies. I think it is AS brand but not positive. I tried pushing a snake down and got it a few feet in but it does seem to hit something other hair, etc. I can almost feel soemthink clunk around I think. This is making me think there is another part to the drain system that is stuck because it will not drain even one drop, it is totally sealed. If I had a block from hair and junk it would slowly leak out like it used to do.
I even took a plunger and with my hand over to seal the open backflow/lever link area I plunged it a few times and no water would move at all. There has got to be another part in this system???...this is annyong me!!
http://www.terrylove.com/images/power_spin.jpg
The two parts you took out are the only ones in the drain. The hair and stuff is packed too tight for the water to drain out. The stoppage is past the point where anything other than snaking will work, and plunging just packs the stuff tighter.
Bob NH
11-22-2006, 09:25 AM
If you are going to snake it, remove the fitting at the overflow above the drain and snake through that hole. You will have fewer corners to go around. You usually can't snake through the drain in the bottom of the tub.
Dunbar Plumbing
11-22-2006, 04:13 PM
Probably hitting the bottom side of the drum trap cap if it is a old old home.
Gencon
11-22-2006, 04:19 PM
Would be nice to be informed of when and why a post was deleted.
plumbbob
11-22-2006, 08:26 PM
I fully support the 'snake the drain solution' We had a similar problem in our tub and the snaking did the trick.
Only it wasn't hair that blocked the drain. Well, it might have been the rat's hair...still attached to his body. Somehow the rat had made it up a few feet from the sewer line in the slab and got stuck where the 2nd floor DWV line met the main. We pulled it up and the water went down in a flash.
It was quite nasty. And the wife made me throw away the snake, despite the cost to replace the whole thing.
