Adding a Laundry Sink
srubin1701
So I want to add a laundry sink next to the washing machine and dryer. I can T into the PVC supply lines or come up through the basement...
The problem is on the Drain side.
Can I simply T into the vertical drain line below where the washing machine pumps its discharge into? ... I'm only 2 feet from the drain.
As another alternative, I could drill the waste line down into the basement and tie into the stack there, but I'm not sure about the vent.
Another thought was to use an AAV, although I get the impression that plumbers arent' particularly happy with them....
Anythoughts are appreciated, I'd like to install this over the thanksgiving break.
Many places will want a vent for both fixtures.
I think that if you use an AAV, that it would be better for the sink, than the washer.
Hammer arrestors on the water supply are a good idea too.
