jsitmers76
I have this recurring sulphur smell from my sump hole. It lasts for about a day and a half and shows up at random. The last time it started smelling was over a month ago, maybe closer to two months.
Is it possible that the ground water contains a lot of sulphur and this is causing the smell?
The only other thing I can think of is that the discharge line for my water softner drains into this sump hole. It normally runs in the middle of the night, so I ran it a few minutes ago while I was awake so that I could smell the water that comes out of the discharge line. As far as I can tell it is normal water (no smell). I smelled inside the unit that accepts the salt and it does not have that smell.
Currently, the sump hole is not covered properly and I will be building a sealed box around it. It will contain an access door so I can access the sump pump if needed, but for the most part it will be 'air tight' (well, as best as I can). This should stop the smell from occupying my entire house for a day at a time, but I would like to know what could be causing it.
I have a septic system that was recently drained and the smell is definately sulphur and not septic odours.
If anyone has experienced this in the past or knows someone who has, I would appreciate any feedback.
Just as a point of reference, I read this http://www.wellowner.org/awaterquality/hydrogensulfide.shtml
and this is where I got the idea that there might be hydrogen sulfide in my ground water that is causing this problem.
