On 8/26/6, after nearly 20 years, we started to get a smell coming from our shower drain. This is a shower that has been used twice a day for the last probably three years. Before that it was used once a day for a couple of years and before that periodically since it was built as an add on as a part of a master suite to our 28 year old home.
Ran liquid Drano, flushed it with the garden hose, cleaned it above the trap with Clorox and a bottle brush. (There is water in the trap and it stays at a constant level when the toilet is flushed, an adjoining bath tub is turned on and water is run in two sinks hooked to the same drain pipes). Called the plumber. He said it was caused by the heavy humidity and will go away. It went away and came back a couple of times. Besides, that answer just didn't sound right. Called the city. A man came out and said it did not smell like sewer gas. He pulled the cap off of the clean out and no odor there.
Ran a snake down the vent pipe, no obstructions. Put a white rubber sink stopper over the drain and put a pitcher of water on it. Kept the smell out of the house and turned the white rubber brown.
Called our contractor and he suggested pouring Clorox in the trap and let it set over night. Didn't work. Poured Liquid Plumber, ¾ bottle, in the trap and left it over night. Didn't work. He also suggested running a snake down and see if it picks up anything. Ran the snake in about eight feet turning it contatntly. Came up with nothing. Just talked to him and he suggested asking the question on this forum.
Thank you out there for the help.
God Bless
Dick
God Bless
Dick
