Raise Cast Iron Radiator due to new wood floors - HELP!!
shoo fly
My house is old - 1925. I just installed new Bruce 3/4" hardwood floors over the existing wood floors which were in bad shape. Now I have to re-connect the cast iron heating radiators in each of the rooms (I removed the radiators and installed the new flooring underneath them also).
The heating sytem is piped with black pipe which is in amazingly good shape. My problem is that I can't find a way to get the fittings to match up now that the radiator sits 3/4" higher than it used to. I tried using a coupling and close nipple to extend the fittings, but this brings them up way too high and I'd have to use some kind of blocking to set the radiator on to get it up higher (I don't want to do this). I guess I could also just cut the legs of the radiator off by 3/4" - which would also be a real pain....
Has anyone run into this and come up with a good solution? Any help is greatly appreciated.
connections
Have you tried pulling up on the valves and elbows? Often there is enough "spring" in the piping to allow them to be raised the distance you need.
crawl space or second floor?
you got some fun ahead of you
you might be able to just pull them up that much li HJ said
or if you are on a crawl space you might need to see
what is holding those pipes in place against the joysts
below the floor... takeing off a pipe strap or
knotching the wood 3/4 of an inch
to get those pipes to raise up that much wont hurt anything..
anything is better than cutting off the legs to the radiators
Yeah - not enogh room to pull them up. I also notched out the holes larger prior to installing the floors and still not enough room. It fells like the pipe underneath goes through a joist and just stops hard when I yank it and try to force it up......
Male / Female Adapter
One additional question for you guys - Is there such a thing as a Male to Female adapter for 1" black pipe? Like a street elbow without the elbow? Or a coupling with male threads on one side and femal on the other?
This might solve my problem as it would be shorter than what I'm using now - a regular cuopling plus a close nipple...
If this stuff is available any idea where I can get it?
plumber1 said:
How bout a street coupling??????
A street coupling - yeah, perfect. But I can't find that anywhere locally or on the net. Any suggestions?
