View Full Version : Vibrating shower pipes
cgrissom
10-26-2006, 10:10 AM
We bought our place 2 1/2 years ago. It's an old house (1924), but supposedly the piping was replaced with new copper piping (I don't know exactly when). When you get about 2 minutes into a shower the pipes will start vibrating loudly, will only stop if we turn down the water. This started just about a week ago. This doesn't happen with any other faucet or appliance. I know I'm going to have to call a plumber, just want to hear what people think the problem is (and how BIG a problem) before I do. It's makes our dog get VERY agitated. Any ideas? Thanks in advance...
jadnashua
10-26-2006, 10:31 AM
Try replacing the washers on the valve stems...sometimes when they get old and hard, they can start to vibrate. Eventually, they'll break and clog things up, while not allowing you to turn it off. As you run the shower, the hot water changes the size of things. My guess...
plumber1
10-26-2006, 12:09 PM
Yes it sounds like the bib washers.
When you repair it use self retaining bib screws to hold the washers. Screws can back out a little and a loose washer can rattle too.
Verdeboy
10-26-2006, 12:10 PM
A lot of times, you get that type of pipe noise when there is a reduction in water pressure for whatever reason. If you have a PRV (pressure reduction valve) that may need to be looked at and/or adjusted.
chassis
11-05-2006, 02:26 PM
Had the same thing, but our situation was made worse by loose pipes, not properly secured to wood framing. Granted, the Moen valve was old and the seals were probably fluttering, but it was made worse because the pipes would bang against anything they were touching. Sounded like a gang of monkeys pounding the pipes with hammers.
I discovered this (unsecured pipes) when I was tearing out the bathroom during my renovation project. The shower valve was also not connected to anything. It was only supported by the vertical piping itself.
plumber1
11-05-2006, 03:21 PM
Moen valve has nothing to flutter....
