Another soldering question
White Tiger
Is soldering brass to copper the same teqnique as copper to copper ? Also what is the best solder and flux to use and propane or Mapp gas. Thanks for the info, your site is the best for the do-it yourselfer.:confused:
Applying more heat to the brass fitting is usually required; make sure the solder goes completely around.
I use tinning flux for best results.
I use Bridgit solder or Oatey lead-free.
