View Full Version : No Hub Couplings really work?
Geo
10-14-2006, 07:31 AM
I have read here that I can insert a wye in a current 3 inch ABS drain pipe under by basement floor by using two no hub couplings. (one on each side of the WYE with stub pieces) I guess the banded ones are better but I cannot find any banded ones locally, only the fernco ones. Where online can I get a banded one?
Also, after I slip the coupling over the pipe and put my other pipe in place how much of a gap is OK between the pipes before sliding over the no hub? It seems if there was an inch gap then toilet paper and stuff would get hung up in this gap and catch on the gap. Or am I worried too much about a small gap?
Thanks guys!!!
Cass
10-14-2006, 07:37 AM
Try a plumbing supply house for the banded couplings.
jimbo
10-14-2006, 08:19 AM
Many folks use the derisive term "Fernco" for a rubber coupling with just a small worm clamp on each end. However, Fernco manufactures a wide range of products, including banded no-hub couplings. They are available at plumbing suppliers and box stores.
10-14-2006, 10:03 AM
No-HubŪ couplings are available at Home Depot and even hardware stores. You only want about 1/4" clearance when the pipe is test fit into the space. That gives the clearance needed for the ridge in the center of the coupling to drop into.
Cass
10-14-2006, 12:11 PM
hj, for what ever reason HD out here does not cary them, only Low*s does.
