nelsonba
10-12-2006, 10:15 AM
I recently boutght a 1931 home and this is my first experience with radiant heat… which I know nothing about. I drained the system a while ago because I needed to move a radiator so I could re-tile a floor. I now need to reconnect the radiator, refill the system and get it working for winter. (I'm in Minnesota and it's 25 degrees right now.) A few questions…
1) It looks like a water supply line is hooked directly into the system. I would assume this is what I would use to fill the system, correct?
2) Once it's full, should the fill valve stay on?
3) Expansion tank… what do I do with that? Do I drain that after I fill the system to ensure that the whole thing doesn't blow up?
4) Any special trick to bleeding the radiators? I would assume you start at the highest level of the house working your way down and just bleed it until only water comes out.
5) When bleeding the radiators, should the system be on?
6) When reconnecting the radiator I took out, should I use teflon tape on the threads?
7) How much pressure should be in the system?
Anything else I'm missing and should know about?
