View Full Version : Delta 1400 Series shower faucet problem
bryanw21157
10-10-2006, 12:30 PM
Hello. I replaced the seats and springs in a 1400 Monitor yesterday.
Now, the handle is VERY loose and gets turned by the shower head 'hose', easily either freezing or burning the person in the shower.
How do I tighten the shaft that the handle attaches to? Do I need to buy a new one?
thanks,
Bryan
Verdeboy
10-10-2006, 01:04 PM
With most Delta faucets, there is usually a little bonnet, or cap, that keeps the parts from moving around. Wrap it with a rag and try tightening it up some more with a channel locks.
Of course, double check to make sure that the handle is tightened as well.
If you need to buy parts, here's a great website, where you can easily find your bath faucet:
http://www.lockplumbing.com/delta/tubsingle.htm
bryanw21157
10-10-2006, 01:33 PM
I was thinking about it and came up w/ this solution....
when I disassembled the unit, I had to pry the 1st half of the
valve body (white plastic piece that the faucet stem is attached to)
out of the sleeve. When I put it together the 1st time, I had the assembly
on backward and hot came out of cold and vice versa. But, it was tight...because I tapped it in with a hammer. When I fixed the hot/cold issue, I didn't tap it in....simply screwed the ring on to hold it in place. I think the little gap left in the assembly from not being tapped in is causing the looseness.
I'll fix the problem and update this thread with the solution.
thanks!
master plumber mark
10-10-2006, 03:21 PM
sometimes you save yourself a lot of
greif if you just change out that whole
cartridge assembly....and not fool
with the seats and springs...
if we are talking about the same
pressure balanced faucet....
