View Full Version : Stinky Dishwasher
Lisa
09-01-2004, 05:05 PM
When I bought the house I am in now, the sink and dishwasher stunk so bad that it took my breath away. I thought it was just old and dirty. I bought a new dishwasher, new plastic plumbing parts, and a new garbage disposal BUT my dishwasher still stinks. It smells like dirty sewer smell. I have had two plumbers come out and both said that they didn't know what it was. They wanted to charge me over 300.00 to smoke the lines, to look for a leak. Before anything else, I wanted to try your sight. Any and all help or suggestions will be greatly appriecated. Thanks in advance.
jimbo
09-01-2004, 06:10 PM
http://terrylove.com/images/sink_dw.jpg
How is the dishwasher drain connected? Is it connected throught an air gap? At a minimum, is is connected above the sink drain trap?
e-plumber
09-01-2004, 08:19 PM
Is there a crawl space under the kitchen? There could be a leak below allowing water to pool, become stagnant and give off the foul odor.
e-plumber
Lisa
09-01-2004, 08:51 PM
The plumber said everything is connected correctly. But I don't know what an air gap is ?
Lisa
09-01-2004, 08:52 PM
e-plumber
I do have a crawl space but supposedly the plumber checked that and I was told everything looked good. Anything I can do myself?
e-plumber
09-01-2004, 09:19 PM
Since you had two different plumbers check the problem, replaced the piping, DW and the disposer unit, (which by the way are known to give off odor at times) have you considered that the hot water is the culprit? It is possible. If you have well water with a water treatment system or a water heater with an anode rod that may be deteriorating, both items can possibly cause a "sewer like" smell.
e-plumber
Lisa
09-02-2004, 12:13 PM
Does this make sense ? The smell was so bad in the sink, the first thing replaced was the garbage disposal. We then replaced the white plastic "pipes" below the sink. There was gray gunk in these plastic pvd pipes and the smell made me vomit. Once the disposal and the pipes were replaced everything seems fine until the smell was in the dishwasher. I bought a new dishwasher but the smell still comes thru the new dishwasher. Could what was cleaned out of the pipes somehow got down in the dishwasher ??? I just don'tknow what to do. I really do appreicate you taking the time to help me. Have a great day.
jimbo
09-02-2004, 12:30 PM
Since you have replaced the piping under the sink, and I am assuming the dishwasher drain hose is new (came with the dishwasher) there is little left unless you are getting sewer smell.
Check the diagram which Terry Love kindly added into my reply above. DOes your piping more or less resemble this? Pay close attention to where in this picture does your drain hose connect. (The pipe labeled Vent is inside the wall and will not be visible)
Lisa
09-02-2004, 02:55 PM
My drain hose does not connect to an air gap fitting. I am at work now so I will not able to explain how it does fit exactly until Monday. If you still are willing to help me, I will talk with you then. Thanks again.
Lisa
09-03-2004, 08:03 AM
Well, I am back...Yesterday was Thursday !! Before I post this message, let me again tell you how much I appreicate all of the help with my problem. This is really a great thing for people like myself that don't any any plumbing knowledge, that can talk with people who do and who don't mind sharing that knowledge.
I looked under my sink. The only dishwasher hose that it visible comes from the bottom of the dishwasher and hooks up directly to the side of the garbage disposal.
Gary Swart
09-03-2004, 08:13 AM
That hose from the bottom of the dishwasher to the garbage disposal is the drain hose and it should be looped and secured under the counter top. If it goes straight from the bottom of the machine into the drain without the loop, that might be the source of the problem.
jimbo
09-03-2004, 09:33 AM
OK, we might be geting close. If that hose does not have a loop in it...that is looped up high, right to the underside of the countertop...before going down again into the disposer, then dirty sink water can back up in that hose into the dishwasher. This can be the source of the odor.
Lisa
09-03-2004, 12:23 PM
ok......I looked and the flexible white hose that comes from the dishwasher directly hooking into the side of the disposal is very long and there is no loop in it.
I wish I could stick around and get this fixed today but it is time for me to go to work now. I bet you this is something I can do myself with your direction. Any and all advise id GREATLY APRRECIATED.
jadnashua
09-03-2004, 01:01 PM
It's not that tough, except for the possibility that there is little room to do what you need to do.
Basically, the hose comes out of the dishwasher's pump (generally on the bottom of the machine). That hose must go up as high as possible (and at least a few inches higher than the exit in the garbage disposer - the top of the cabinet is better) prior to draining into the garbage disposer. Some hoses come with a clip or clamp to screw or nail the clamp where it needs to go and hold the hose in place. You may need to buy something. A sturdy piece of wire wrapped around a screw or nail and then the hose would work, too, but a clamp is better (less likely to get a kink or fall off).
This loop prevents drain water from going back into the dishwasher - once it is pumped over the high spot, it drains into the garbage disposer.
Gary Swart
09-05-2004, 10:31 AM
I would not use wire, it could cut through the hose in time. Plumber's tape would be better. I'd make 2 or 3 clamps to avoid the possibility of the hose kinking. You want to keep the loop as gently as possible. I'm amazed that 2 plumbers missed such a basic thing! I don't think I'd call on them again.
Lisa
09-07-2004, 10:23 AM
This weekend, I started working on the suggestions. The hose that is there now is not long enough or flexible enough to do what I need it to do. I will need to purchase a hose,clamp , etc. I will keep you posted. Thanks. I hope this will solve the problem.
Lisa
09-13-2004, 10:35 AM
I was able to fix the dishwasher drain hose this weekend with the help of my father and a friend. I am going to try it out and see if the smell is gone. I will let you know. Is there anything I should do first .......maybe pour a cleaning solution in the bottom of dishwasher ? anything like that before I wash dishes again ?
Deb
09-13-2004, 11:10 AM
You can pour some bleach in the dishwasher and run it through a cycle. Always use bleach by itself, never mix with any other types of cleaners.
I am beginning to question if what you have is a plumbing related odor. What exactly did the plumbers say about the odor? Did they believe that it was sewer gas (although I don't know how much trust I would put in plumbers that did not notice the non-loop in the dw drain line and deal with it)? Did they check to make sure trap was maintaining its water seal? Was any kind of test done on the vent to be sure that there is not a break there? Even though the dishwasher hose is not looped, this should not be causing the horrible smells you are describing, especially from all new piping, disposer, dw. The major reason for the loop/air gap rule is so that if the sink backs up, the backup will not run through the dishwasher hose and into the dishwasher.
You have basically replaced everything that comes in contact with the drainage system from the fixtures to the wall. So, I would be maybe looking for another source for the smell--a small dead animal(s) rotting in the toe kick or wall, mold, mildew, etc. Odors can be tough to identify, but it is necessary, since the remedy is dependant on the cause.
Deb
The Pipewench
Lisa
09-13-2004, 06:03 PM
Deb, I think the smell came from the the garbage disposal at first. When the old one was removed and the pvc pipes replaced, the gray gunk that was in the pipes definetly was the smell and honestly, it made my gag.
I was really shocked when I replaced everything and still smelled it. I don't think it is an animal smell. But then again, since I don't know what it is, how could I say that! But the garbage disposal does not smell now, just the dishwasher. The dishwasher is finished it cycle and you open the door, most times you should smell a lemonly clean smell. but I don't. The smell is nasty, dirty,I would say a sewer smell. So I don't know. I will run the bleach thru and test it after that. Thanks very much , it is appreicated.
Lisa
BrianF
09-14-2004, 08:00 PM
I would definitely check out the dead animal thing. It could be a mouse or other creature that expired near or inside of an enclosed area and the smell shifting.
Sewer gas is nasty. Probably what it is. Is the house properly vented overall? I have seen some houses that have all the traps clear out when you flush a toilet.
A vacuum could exist in your system causing a trap to empty out and allow sewer gas to enter the home.
Brian
Lisa
09-15-2004, 06:23 PM
Well, the smell DID NOT disappear so I am back where I started from. I have been there over a year. I can't imagine the smell being a dead animal. I am wondering if by using the dishwasher could be harmful ??? The smell has been consistant as long as I have been there so what ever it is, doesn't seem to be affected by bleach,cleaner,etc. I live in Nashville, TN. I have had two plumbers come out and they don't see anything wrong, don't smell anything but they both told me that they don't smell anything anywhere any longer, by being a plumber for so long. I will check this sight often to check any ideas and suggestions. ALL IS REALLY APPRECIATED. Thanks so much. Lisa
Alexdc99
09-17-2004, 09:55 AM
Sounds like bacteria in the hot water tank. I would add clorine to the tank, let it sit for an hour drain and try try running a wash again. I didn't read in any previous posts if the water source is city water or well water. Bacteria in the hot water tank can smell horrible.
lovetohelpya
04-01-2007, 08:11 PM
Have you checked your vent pipe(s) for clogs?
If your kitchen is far enough away from the main stack vent, it will have it's own vent stack coming out of the roof. Have someone go on the roof with a flashlight and look down the stack. (I have found bird's nests, bee hives, dead squirrels, leaves, ect. stuck in vents.) If it's plugged, shove a garden hose down it and turn it on. *Have someone stay by the kitchen sink to make sure the water doesn't back up there.
It may not be the vent, but at least you know a way to fix it if it is.
;) Good luck!!
Ulysse
07-14-2007, 07:22 AM
I also had the same problem. I hope that you solved yours by this time. But just in case.
Check if you have a size restriction in the discharge hose at the point where the drain hose connects to the sink pipe. I changed to a larger size entry and it solved the problem I had with my new diswasher. I had assumed that since the old diswasher was happy with that connection, so would the new one ! Bad conclusion.
Ulysse
tristessa
10-23-2009, 11:28 PM
I have this today, and a search brought me here. The smell is horrific. At first, it was just like mothballs, but it's been getting worse. Yesterday, one sink (not the one by the dishwasher) was putting out black gunk (looked like coffee grounds, felt like dirt), and the hot water pressure is way down. No other sinks in the house had this issue. I cleaned the aerator of the black gunk, and it was okay for a while. Then the gunk happened again an hour later, but it's been fine since then, except low pressure for hot only.
However, today the dishwasher stinks. At first we thought it had to be the hot water heater, but all other sinks in the house are fine. Nothing has changed in the way the dishwasher is connected, but perhaps something is clogged somewhere? We tried using a plunger to no avail. I cannot afford to replace the dishwasher, since it's 5 months old. The water heater is old (11 or 12 I think). The disposal is 8 years old. Please help me solve this mystery.
Cass
10-24-2009, 05:41 AM
When was your house built?
Do you use the water heater that is built into the dish washer?
Is there a drain pipe coming out of the wall that all the the other pipes connect to or does it come up from the floor...
Lastly if the drain is coming out of the wall is it pitched so the water would run toward the wall or is it pitched so the water would run back into the cabinit...
Do you have a digital camera to post pics with?
tristessa
10-24-2009, 01:13 PM
Thanks for posting.
House was built in 1961.
I'm not sure how to answer the next question. I do use the high heat setting on the dishwasher. I guess that means the dishwasher heats the water?
The drain pipe comes out of the wall. The sink has two drains, one goes through the disposal. They come down, through a trap (one trap per drain) then into the pipe that goes into the wall. This morning I took the traps out and they were clean, and virtually odorless, so I guess this is a different problem than the original post after all.
That drain pipe seems to be level, but it's short so it's hard to tell. I do have a camera. I'll post a picture soon.
Another thing. After finding the traps clean, I drained some water out of the water heater in the basement. It was clear and odorless.
tristessa
10-24-2009, 01:22 PM
under the sink that is next to the stinky dishwasher
http://www.happen.net/img/undersink.jpg
Doherty Plumbing
10-24-2009, 04:16 PM
The reason you run the drain hose up high from a dishwasher isn't to "trap" the dishwasher at all. You do that to help prevent the sink from backing up into the dishwasher. If you look at the side of a dishwasher you'll see that they have their own built in trap!
The smell you're getting COULD be coming from your HWT but it's doubtful to me because you say this is the only place that it smells. If it was your HWT you'd notice the smell (atleast somewhat) at other fixtures in the house.
I would guess that you're siphoning a trap dry somewhere. But if you had a professional plumber check everything and it looks out then I'm a bit stumped.
Do a simple test and run the dishwasher until it fills up and then put it on to it's drain cycle. While it's draining put your ear up close to the sink's basket strainers and listen for the sound of it sucking in air. All you should hear basically is running water.
