FYI: American standard compact EL
Bill Arden
Computer Programmer
MN, USA
www.billarden.com
I have been using a American standard compact EL for some time, but the design has a flaw at the exit flange area. It turns sharply and then has too small of a hole. I used a rotozip and cut off the flange to enlarge the hole.
I’ve had to do this twice since the first one cracked after 6 months.
It has been working for a long time without leaks, but I’m mainly thinking of the future and wondering if I can really leave it this way?
Or more importantly if they will ever fix the problem (if they haven’t already)?
Re: American Standard Water Closets
I don't have a single clue as to why A.S. put 2 90deg turns at the waste outlet of the water closet bowl, and to my mind it's ridiculous. Water is supposed to flow and efficiently. There is nothing efficient about 2 (count em) 90deg turns in a water closet flush tube. And Kohler does the same thing.
If I am recommending a new Water Closet I inform the client, that he wants neither brand, in the "competitive cost range". I ALWAYS recommend a w.c. with a smooth flow to exit.
One more thing, w.c. outlets used to be at least 2-1/2"dia., on these "competitive" units the exit hole approaches 2" in dia. Is some poor starving plumber designing these bowls so that he has work unplugging them after normal use or what?
I have even sent them, AM STD & Kohler e-mails inquiring why they have redesigned a good working w.c. to an ugly no-flow P.O.S. that they are trying to foist on an unsuspecting public. Can anyone enlighten me?:confused:
I hope so,
Rudy
EAT "WILD ALASKA SALMON" IT'S GOOD FOR YOU AND YOURS!!!:) :) :)
I think part of the problem is that they design to the golf ball standard.
I don’t know anyone that produces small hard round items.
They really should make a better testing standard that includes different shapes and densities.
Try flushing several 3-inch long 2-inch wide oblong pieces with some toilet paper thrown in. This particular design would fail as it has a pocket just after the sharp 90-degree bend downwards.
The pointed part sticks into the pocket. I removed the toilet while it was plugged just to see where it plugged.
