Flange Too High
T27
Baltimore, MD
I just started to install a new Drake at the end of a bathroom remodel. The flange is too high and I have a 1/4 inch under the toilet to shim. Everything was ok until I replaced the old tile floor with hardwood and the floor level dropped by a 1/2 inch or so. The drainpipes are copper. I can get at the drain from below if absolutely necessary. I really don't want to fill the gap with caulk.
From previous posts, I'd think I should sweat off the old flange, cut the drain pipe off a bit and install a new flange.
Sounds simple. What should I watch out for?
If your going to add a new flange don't worry about unsweating the pipe, cut the pipe below, and new pipe elbow and flange, should be simple.
Thanks for the reply. If I go in from below, I'll end up with a sheetrock repair. That"s my last resort
I'm still leaning towards sweat and cut. Is there any chance that the flange is glued or threaded on?
Nope it is sweated on, sorry to tell you that, other option is to set toilet on a 1/4" platform.
I'd not want to try a unsweat that flange, you can start a fire, it will take too much heat, and to do it that way, you will need access to below anyways.
flange too high, part II
so, would you replace the flange if it happened to be cast iron (instead of copper)? same thing happend to us. i'd hate to go thru the time/expense of taking out the cast iron flange to drop the toilet 1/4". An suggestions? thanks
flange
Flanges always install from above the floor. You should be able to unsweat the brass flange by heating the interior of the pipe and then lower it. A cast iron flange is the easiest to lower because you can break it off and install a new one in a matter of minutes.
