Accidental hole in 3" PVC Drain Pipe
Shoun
I drilled a 3/16" hole in my PVC drain pipe by accident when hanging a towel rack. Should I drill out the hole to 1/2" and glue in a plug? The pipe is tight between two walls and I'm not sure if I can get two couplers in to replace the whole section of pipe.
What's the best way to fix this? Does anybody make 1/4" plugs??
Thanks for your help!
There are a few things you can do
1 take a hot, almost red hot, knife or similar and melt the plastic pipe to fill / cover the hole.
2 get a 1/4" drill and tap and thread the hole and install a plug.
3 fill the hole with epoxy
4 cut the pipe in 2 places about 4" on either side of the hole and install a new peice of pipe with 2 banded couplings.
Thank you
Thanks, I'll go with the 1/4" tap and plug option. It seems easier for to guarantee a joint without water leak.
