railcrew
I am replacing our vinyl flooring and noticed my toilet flange doesn't look like any I've seen yet. It is solid cast iron with no "slots" for the flange bolts, just two old rusted bolts sticking up. It appears to me sweated on with lead. The pipe itself is jagged (where it was cut with a torch?) and sticks up above the flange slightly in spots. I have no real problems, no leaks or buckled floor. It (flange) does sit level with the floor, not slightly above. the wax ring with horn works fine. I guess my question is, if I accidentelly break one of the bolts how do I replace it? is it the screw in type or the kind that has the flat "head" under the flange?
Having the jagged pipe sticking up is it possible to add an extension?
