I tried to replace the 50 year old toilet in my mother's house. After installing a new American Standard complete toilet I had a leak from the floor. I replaced the wax ring again and it started leaking after 2 days. I have read everything I could find on several plumbing web sites and have realized the following. The old toilet had considerable mounds of grout under the toilet. The floor flange is above the floor by about 3/8". When I put the new toilet on I did not check see if it rocked nor did I check to see if was level. I think the grout under the original toilet was to raise it up and level the toilet. Since I don't have a few days to do a grout build up and let it dry and then mybe have to redo it ( mom needs the toilet working in a few hours at best) I started reading about a spacer. Most things I read indicted I either have to lower the pipe or raise the floor. Several people have used marble, corian, pieces of floor tile or plywood under the toilet to raise it in order to deal with the raised flange. I found a 14" x 18" cutting board at Home Depot which is made of high density polyethylene. What would you people think of making a spacer for under the toilet out of this material? I would put the toilet on the piece, tace it, make an opening for the flange then cut it with wood tools. It has at least the harness and tensile strenght of plywood. It will never rot or need to be painted or water proofed. It is anti microbal, abrasion and impact resistant. Seems like a good choice to raise the toilet then I will also level it with shims if necessary. Also what do you guys say about the Fluidmaster or Fernco non-wax toilet seals? Might use it here. Any feedback or comments would be appreciated. Currently there are one inch square ceramic floor tiles on the floor. By the way the flange is soldered to the end of the 4" drain pipe. It is not anchored to the floor. Should I put something under it so I can anchor? Any comments would be appreciated. Help me make mom happy.
