Diverter stuck??
Pitterpat
HandyWOMAN
Indianapolis
Looked at a shower that the knob on the shower diverter will not work. I think this is a Delta, but I know the diverter knob is on top of the tub faucet spout. Is this fixable or should the tub faucet spout be replaced?
Thanks, Pat
If the shower diverter is on the tub spout, it has nothing to do with the type or brand of faucet. Replace the diverter tub spout.
Tub spouts may be one of two types...threaded screw-on (use teflon tape on the male threads wrapped clockwise as the threaded end faces you) or unthreaded slide-on with a set screw holding it in place. Check for a slot underneath the spout for an Allen wrench set screw.
You can get a one-size-fits-all that will usually work.
Good luck!
Mike
diverter
The other difference in diverters is that some have the thread at the wall, and others have it at the front of the spout by the diverter knob. Only a cheap plastic "fit all" spout will accomodate either type of connection, otherwise get a direct replacement for it.
