I had to remove a toilet to install ceramic tile and when I went to replace, I had to cut out the bolts that hold the tank to the bowl because they started to leak. After replacement a leak started in the back, coming from between the tank and bowl. I replaced the gasket, and is still leaking. I have tried to replace this gasket twice, and tried to reposition it many, many times, making sure the area is completely clean - still leaking. I even tried to reinstall the old gasket. I have the right gasket (already been asked several times), and this seems to be a no-brainer installation job - install gasket, place on bowl, tighten bolts... So what am I doing wrong?
