View Full Version : clean out plug
rihokie25
01-12-2005, 05:10 AM
What's the best way to remove a corroded clean out plug. The plug probably hasn't been removed in at least ten years and won't budge with a wrench. Any siggestions on how to free it?
You have used a wrench, but have you used the wrench and a hammer to hit the wrench? There are many ways to remove a plug ranging from more force to cutting it out. We cannot advise the best way without trying the different options to see what works.
Bob's HandyGuy
01-12-2005, 06:50 PM
If it's one of those brass ones on the bottom of an old cast iron trap, you may have a cuss-fest removing it. Try just catching a chisel on the outside edge then hammering so as to rotate it. Do this all around the diameter of the plug. (Handyman, not a plumber.)
Phatbrain
01-13-2005, 02:12 PM
This has worked for me, but I don't know anything and it's not my fault...
Take two hammers (size doesn’t matter :), but I use small ones) of equal weight and give the fitting a sharp rap at the same time on opposite sides. Repeat the rapping around the fitting.
Good luck and don't crack the pipes
