I recently installed a new 1/2 hp shallow well jet pump with a 42 gallon air bladder tank pressured at 18 psi. There is a water tank under my driveway that is approximately 6' x 8' and 7' deep. I think it holds 2000 gallons of water. The pump is installed on the driveway surface, so the approximate depth of the pump to the bottom of the tank is less than 10 feet.
The system ran correctly for 1 month. That is, it would run the pump until the pressure guage reached 38 psi, then it would cut off. And it would turn on when the pressure went below 20 psi.
I am re-plumbing the house, so after I installed the system, I left it turned off unless I needed water. This meant it was started approximately 10 times per week for the first month.
Now, it has a problem: it will not reach the 38 psi cut off. It pumps up from 0 psi to 18-22 psi "normally" but then it just keeps running with no more increase in pressure.
It can hold this 20 psi pressure at least overnight.
So I changed the foot valve, hoping this was the problem. There was some sediment (very small rocks/sand) in the pipe that fell out when the foot valve was removed, but I was not the one who removed it, so I only heard about it, I did not see how much. The tank was cleaned prior to the pump installation, but it was pretty dirty before then.
I re-primed the pump, and the pressure reached 10 psi then stopped, so I drained the house water pressure, and re-primed the pump. This time it reached 18 psi. So I repeated the process, and it reached 22 psi. Repeating the process would not increase this pressure any more.
To my ear, the pump still sounds normal with no clattering or other troubling noises.
I am certain that the water level in the tank is about 6" above the foot valve. But this also means that there is only 1 foot of water in the tank.
I have read some troubleshooting guides on the Internet, but none seem to address this problem.
Since the pressure holds overnight, can I assume that there are no leaks in the system?
The last things that I can imagine are that there is still air in the suction line, the water level is too low, or there is a problem with the pump (impeller?) which may have resulted from the sediment.
Can anyone give me some advice?
