Reusing ball valve
ToolsRMe
Colorado
In another thread, *Extending shower/bath supply lines*, it was mentioned that one should not bother attempting to reuse a fitting. I agree. I've had very little luck with that and just throw the fitting away. Except ...
Because of some, uh, interesting plumbing I had to reuse one end of a half-inch ball valve.
I cleaned the valve as best I could (but could not get down to bare brass), refluxed, and soldered. The joint held.
So some basic questions:
(a) Is a brass ball valve considered a fitting?
(b) Am I looking at problems in the future?
b
it will be fine.
hj said:
NOT getting it down to brass probably made it a better joint, because the joint was "pretinned".
Well, I've learned something new today. Thanks.
A follow-up question. Since the rules for a brass, uh, fitting (Is it a fitting?) seems to be different than for a copper fitting, is sweating different? That is, does one heat the (brass) valve or the copper?
Seems to me that you'd want to heat the valve.
