View Full Version : water heater install question
mzprfkt
09-08-2006, 06:24 AM
Hi all, great site here.
We installed a Richmond 50gal gas heater yesterday.....everything was fine till we noticed the T&P valve leaking....
But it isn't leaking through the valve.....its leaking through the threads. Now this T&P was factory installed.
Any ideas to stop this?? I know about pressure and heat with these valves, but I would think if it was either of those, it would be leaking through the valve itself and not through the threading into the heater.
Any advice would be very appreciated.
Gary Swart
09-08-2006, 08:39 AM
Sounds like it wasn't screwed in tightly. Turn the water off, take the drain pipe off the TP, remove it, redope or tape the threads, and put it back on.
mzprfkt
09-08-2006, 11:18 AM
thanks Gary done...
we were actually afraid to do this cause it stated to have a pro only install it, but we are now leak free.
Thank you
Gary Swart
09-08-2006, 12:06 PM
If it will make you feel better, you can send me a check for $150.:D
Mikey
09-08-2006, 12:09 PM
...and a hell of a deal it is.
Dunbar Plumbing
09-08-2006, 12:38 PM
The tank was probably assembled on a monday or friday....the two worst days of of human error.
It would be nice if you could specify a date on certain items built in manufacturing.
